Harley Davidson WL recommendation for air filter
  • 41craig
    • Nov 2010
    • 410
    Cotten; I had the carb that came with the bike, but not the correct one. It had a 1 1/4 linkert with 2 air horn mounting holes. Polished so that you couldn't read the number on top. I put a Mikuni on it the next year and had no problems. Except for the ugly appearance. To the original point. I bought a K&N filter years back and had to trim the outer edge with an Xacto Knife to get to fit the OEM J Slot.
    Craig
      • 8243
      I guess my point, Craig,..
      Was that it wasn't the aircleaner or carb that backfired.
      Nobody was bubble-testing in 1973.
      If they did, they kept it a secret.
        • 8243
        Sorry to butt back in, Folks,..
        But let's not forget the ol' too-slow potato-potato idle interrupted by a snap of the throttle while its still on the kickstand.
        If I wanted a fire, I'd try that first.
        • 41craig
          • Nov 2010
          • 410
          Cotten; The only bubble test back then was with cold beer.
          Craig
            • 8243
            Craig
            I put out a burning VL at this meet, Craig!
            http://virtualindian.org/8eventpontiac.htm
            It was an Augsburger bock, and didn't need to be so cold.
            • 41craig
              • Nov 2010
              • 410
              Cotten; Beer has solved many problems over the years. By the way; Did you used to vend at J&P meets in Chicago and Belleville, Il. back in the 1980's. I remember a dark haired gentleman selling rebuilt Likerts at the meets.
              Craig
                • 8243
                Not me, Craig!
                I might have been standing behind you in the crowd...
                  • 8243
                  Back to air filters, Folks!
                  I really wish I could remember where I found the one on top of this stack.
                  Those were the days.
                  Dumpsters were glorious.
                  (sigh)
                  • epazikas
                    • Dec 2018
                    • 104
                    Originally posted by Jerry Wieland View Post
                    The are more than a few reasons for backfire when starting a bike utilizing a Linkert carburetor as Cotton has mentioned a few. From my experience most of them occur when someone starting a bike has both the choke plate and the throttle plate wide open at the same time. This is a no-no on a Linkert. It causes a severe lean condition prone to creating fires.
                    Jerry
                    Hi Jerry, this was EXACTLY what I was instructed to to, I.e. open fully the choke and throttle wide open when starting the bike. I never did that before and was told this was was the right way of doing it. I think you just solve the mystery!!! Thank you! Ed
                      • 8243
                      To dial it in a little better, Ed,..
                      The idle bleed circuit only works when the throttledisc is close to the idle bleed holes in the side of the bore, close to closed.
                      (The circuit reverses at higher speeds... This transition is magical at very least.)
                      If the idle screw has been set, t'aint never really closed.
                      Wide open throttle *might* help choking, but once the choke is opened and the ignition is hot, the throttle need only be 'cracked' open a little to start.
                      Or so I read on the internet.
