Rubber covered metal base gaskets
  • montuckymatt
    • Jan 2019
    • 45
    I have a set and was wondering if they are reusable. I tore down my top end with less than 1000 miles on rebuild for a leaky nipple. (1937U)The base gaskets still look good. Just wondering if new ones are recommended as they are close to $30 a set new.
    Nothing left to do but smile, smile, smile....
    -good ol GD
    • 8243
    Hope so, huh, Matt!
    There is no doubt that the manufacturer would say no.
    No provider in his right mind would declare his product re-useable.
    • aumick10
      • Nov 2018
      • 465
      There is some internal crankcase pressure on that joint. Not much but it needs some sealing, otherwise it will weep.
