1949 WL Stop Light Switch & Hardware
  • 1962300
    • Jun 2015
    • 58
    Anyone have a good couple of pictures showing the correct set up for the Brake Light Switch AND its Return Spring AND the Puller (that I believe acts as a wire to keep the rear wheel locked when changing the tire)?
    Thanks!
    Matt Allyn
    1932 Ford Roadster / 1949 Mercury Coupe / 1949 Harley Davidson 45 / 1957 Cadillac Eldorado Biarritz Convertible / 1957 Lincoln Premiere Convertible / 1959 Lambretta TV175 / 1962 Sunbeam Alpine Convertible / 1962 Chrysler New Yorker Station Wagon / 1962 Chrysler 300H / 1962 Chrysler 300 Sport / 1964 International Travelall / 2015 Tesla Model S
    • 4789
    The clamp on puller is not part of the brake light switch mechanism on a 45, however it does act as a stop for the purpose of locking the brake. It is mounted on the rear brake rod wher it can be loosened, rotated and tightened to hit the rear chainguard front mounting bolt head to lock the rod. The brake switch uses a longer pull wire than big twins and it attaches directly to the brake pedal. So switch attached to cross shaft at side rail, spring, pullwire to pedal, that is the whole assembly. If you have a generic brake switch kit the pull wire will be too short.
    • Architect
      • Dec 2014
      • 283
      Robbie, just finished getting mine all setup after getting rid of the Chinese solution. Just as a double check, can you post a pick of the brake light switch and springs but from the side? Want to see which holes on the brakes pedal you have everything going to. Thanks
      • 1962300
        • Jun 2015
        • 58
        I think I could benefit from such an image as well.
        Matt Allyn
        • 1962300
          • Jun 2015
          • 58
          Look at this mess; cannot be correct!
          (Don't know why I cannot seem to upload the image straight)
          Matt Allyn
          • 1962300
            • Jun 2015
            • 58
            Stoplight Switch...
            Spring....
            "Piano" Wire to Brake Pedal
            I am missing that Piano Wire entirely.
            Anyone know the thickness of the wire?
            Anyone know the length of the wire?
            Anyone know the exact hole it attaches to on the brake pedal side?
            I assume I will have to make up the bends myself to create it.
            Thanks!
            Matt Allyn
