34 Vl/VD specs
  • Bills37
    • Jan 2010
    • 247
    34 Vl/VD specs
    Anyone have the head bolt torque and valve lash specs for a 34 VD 74 cu in.?
    • 2042
    They did not have torque specs..Most flatheads are .005 intake .007 exhaust
    • Tommo
      • Sep 2001
      • 1320
      Nicholson's Motorcycle Maintenance Manual says 50 to 55 foot pounds for all 1930 to 1947 sv big twins
      Peter Thomson, a.k.a. Tommo
      A.M.C.A. # 2777
        • 5955
        Back in the '60's when I asked my local dealerships wrench for a torque setting his reply was "Tight is tight and too tight is broken".
          I run 0.004" clearance on the inlet valves, 0.006" on the exhaust valves, and pull up the heads to 60 pounds feet with iron heads, then go over the bolts again by hand the first time the engine gets hot. Run a tap through all the head bolt threads first. Stay away from blue Teflon head gaskets.
          • Bills37
            • Jan 2010
            • 247
            Thanks for the info gentlemen.
              • 2042
              Do not retighten the bolts when hot..3 short warm cycles with cool down..then check to see if tight
