I bought a new set of cables from v-twin with all the parts. Looks pretty straight up as far as assembly for new handlebars except for two pieces. They both are slotted and have holes like the cable should run through them but my books don't show them anywhere.image.jpgAny ideas? Thanks!
1936 up handlebar control cables
You push the end of the wire through them and bend them over in the slot and solder the ends to make sure they don't come loose. The above post has it right. Not sure about what you got from V-Twin but this is how it is supposed to work. You say cable but do you mean wire because that is what it should be a solid wire not a braded cable and mine have all come with nothing on the ends just long (cut to length) bare wire.
Tom (Rollo) Hardy
AMCA #12766
