UL throttle cable bracket
  • Ward
    • Apr 2018
    • 22
    Can any one post a pic of how the cable bracket mounts. I bought an L shaped bracket that's supposed to be for a UL, but i don't see how it fits my m88 and aluminum heads... It looks like I have the correct arm. Thanks.
  • 1950Panhead
    • Jun 2010
    • 343
    Bracket under left front head bolt, photo page 129
    • Ward
      • Apr 2018
      • 22
      Page 129 of what book?
        • 4789
        Palmer's 2nd ed.
        • Speeding Big Twin
          • Mar 2010
          • 433
          Ward, I sent you a PM.
          Eric
            • 5955
            • knucklehead 61
              • Sep 2016
              • 350
              m-88 on a UL? that's way too small of carb for a 74" flathead.
                • 2024
                No - M88 is basically the same carburetor as the M51 that came stock on UL and they are listed as replacements for each other.
                  • 4789
                  Standard M88 has a 15/16 venturi, internal bowl vent, and a fixed high speed jet. However all that can be changed to match the M51 specs of adjustable high speed, 1-1/16 venturi, and external bowl vent. Throttle arm is the same.
                    • 8243
                    Just for clarity Folks,
                    All bowl vents are external (except for that infernal M53 series drool pit).
                    M88 shown in attachment.
                    Air correction circuit vents to the main nozzle can be from the throat ('internal'), as were most military and most Indian carburetors, or side-vented ('external') through a hole in the side of the body.
                    So an Indian 1 1/16" (or even 1 1/1/8") venturi could work in an M88 without boogering a hole.
                    • Ward
                      • Apr 2018
                      • 22
                      Thanks for the help and all the replies! I appreciate everyone's experience and knowledge. I was messed up on the throttle bracket, making it hard when it was easy. Hadn't worked on a Flatty for 40 years.
