tappet help
  • DCoul
    • Jan 2016
    • 165
    tappet help
    You've probably seen these before. The roller is real pitted. Question: Do you drill out the axel? Press it out? How do you remove this one and install the new axel ?
    Thanks.
    tappet.JPGSorry for another rookie question.
    • 8247
    DCoul!
    Get a carbide "spade" drill, and only relieve each side to where the pin can then be drifted out safely.
      • 2044
      various suppliers for this tool
      Antique and Modern Motorcycle Parts and Accessories. Retrocycle specializes in the restoration of antique Harleys
      • DCoul
        • Jan 2016
        • 165
        I'm assuming that the tool also flares the ends of the axel.
          • 2044
          Yes,or the tool breaks in half if you do it wrong..I've had one for many years.I pull up tight in vise,tap the tool with brass drift[not in instructions,my way],tighten vise etc...If you go too far it will bind the roller.Make sure you are centered first,between the balls.
          • DCoul
            • Jan 2016
            • 165
            Says Big Twin, Sportster, and Evo. It works with the 45 tappets?
              • 2044
              just did a set last week..they use the same roller kit as well[Crane]
              • DCoul
                • Jan 2016
                • 165
                Thanks guys.
