VL rim offset
  • Buster
    • 384
    VL rim offset
    From the splined side of the hub, is the correct off set for a 19" VL rim 1/16"? Thanks!!
  • Steve Slocombe
    • Jan 2003
    • 2176
    Dear Buster, yes around that. If you lie the wheel on its back with the splines facing upwards, a long straghtedge across the splines will clear the rim by say 2-3 mm each side.
    • Jim
      • Sep 2001
      • 783
      Just wondering.... how "critical" is the offset? I mean... a 1/16" isn't much at all. What would "happen" if the wheels were perfectly centered with NO offset?
      Jim
      AMCA #6520
      • Rubone
        • Aug 2004
        • 4773
        Don't confuse the term "offset". It doesn't mean the wheel isn't centered. It is merely a means of measuring the asymmetrically built hub to get it centered in the rim. And the common way to measure it back then was a straightedge and the hub "offset to one side or the other within that width, which actually "centers" it. Totally different than a wheel offset in a frame.
        • Jim
          • Sep 2001
          • 783
          Thanks! That clears it up!! I never really knew what that meant... so I asked!! ;^)
          Jim
          AMCA #6520
