1940 ULH Rear axel sleeve collar
  • Mbade
    Mbade
    • Mar 2015
    • 6
    When installing the rear axel , does the rear axel sleeve collar part number 41596-30 go on the inside or the outside of the frame ? I can't seem to find a close up photo of the rear axel setup
    Should be on the outside, like the VL, in fact it is the same part number.
      • 4791
      It serves a dual purpose, but the primary one is as a point for the axle adjuster to push against.
      • Mbade
        Mbade
        • Mar 2015
        • 6
        Thank you that makes sense
