1949 Harley "45" Oil Change
  • 1962300
    • Jun 2015
    • 58
    Anyone have a good method for draining the oil from the right side Oil Tank without it being a complete mess?
    Removing the drain plug at the base of the tank, will drop the oil all over the front of the motor.
    I have tried to pump it out, via a hand pump with a hose in the tank...but I don't think it really drains out fully.
    And...is there also a drain plug at the base of the engine for if & when the oil decides to sump in the bottom; due to me not starting it weekly?
    Thanks!
    Matt Allyn
    1932 Ford Roadster / 1949 Mercury Coupe / 1949 Harley Davidson 45 / 1957 Cadillac Eldorado Biarritz Convertible / 1957 Lincoln Premiere Convertible / 1959 Lambretta TV175 / 1962 Sunbeam Alpine Convertible / 1962 Chrysler New Yorker Station Wagon / 1962 Chrysler 300H / 1962 Chrysler 300 Sport / 1964 International Travelall / 2015 Tesla Model S
  • armand55
    • Feb 2015
    • 6
    I put cheap aluminum foil over the top of the motor. It forms well and covers the head area from drips. I then use a piece of plastic gutter cut to length to go to the drain pan. This works well if you don't let the gutter drop.
    • Architect
      • Dec 2014
      • 283
      I have a plastic oil pan that fits under the tank and on top of the head. And I just sit there while it drips.
