VL front axle question
  • VL front axle question
    Putting together my VL front end. With rockers, brake drum, and hub installed, the axle and axle spacer appear to be too short. Interior dimension at rocker holes between two sides of rear ridge fork is 200 mm and axle (not including head for wrench) is 9 1/8" long. The rear fork does not appear to have ever been damaged, front fork has been straightened in past, however lines up exactly with rear fork and rockers bolt on easily. According to forging numbers in Steve Slocombe's book, I have VL rockers. When I put all together loose there is approx 7/16" space between axle spacer and hub. The end of the axle barely (maybe 1/8") sticks out of brake side rocker and when brake drum is installed, does not extend past nut at outside of rocker on brake drum sleeve. What dimension in this is wrong, any help appreciated. Thanks!!
    Buster, Have any photos of set-up you can post?
    William Edwards, AMCA #10035
      I am going to try and get some photos on this morning, thanks.
        Here goes a try with photos
        If I could verify correct interior distance between rocker holes in forks and correct length of axle (including or not including hex head) and length of axle spacer this would tell me if fork is bent or if axle and spacer is wrong. Thanks for any help.
          Trying again on photos that did not go through first time.
            One more photo
              Roughly measured my 36 between the Ibeam and it was 7.5 inches or 190 mm.
