VLD Fender
  • 1970 XLCH
    • Nov 2010
    • 177
    VLD Fender
    Can anyone tell me if my vl rear fender needs work , or is this how they came ? I have attached a picture of my rear fender ( I don't know if it came thru or not , my first try ) . The picture is left front down where the insert screws to it . It looks pretty wavy to me , but the insert mounts nicely . Does anyone have a close up picture of theirs ?
  • Ric Bolduc
    AMCA Member since 2000
    • Feb 2012
    • 109
    • Peter Cooke
      • Aug 2012
      • 570
      Here's another one.
      http://www.ebay.com/itm/1934-36-VL-R...8bc767&vxp=mtr
      • wideglide38
        • Jul 2008
        • 656
        Does anyone have a spare insert for a '34-'36 rear fender they would like to part with (sell)? I am in need of one. Pls PM if so.
        William
        William Edwards, AMCA #10035
        • 1970 XLCH
          • Nov 2010
          • 177
          Thank you Ric ! Looks like i need to do some body work . Does the lower fender have the same ridge as the upper fender, or is that just a indented line in the steel ?
          Thank you , Mike
          • 1970 XLCH
            • Nov 2010
            • 177
            Thank you , Peter
            • 1970 XLCH
              • Nov 2010
              • 177
              Thank you for the picture , William . I think Vl heaven has them
              Mike
              • Rollo
                • Nov 2008
                • 599
                Call Tom Feeser at Replicant Metal in PA. 717-626-1618 www.replicantmetals.com. He has exact replacement repo fenders and probably cheaper than reworking yours unless you are doing it yourself. His stuff bolts right up as long as your frame is straight. None of that bending, banging ,beating, bashing to coax into place like V-Twin stuff.
                Tom (Rollo) Hardy
                AMCA#12766
                • wideglide38
                  • Jul 2008
                  • 656
                  Tom, I had already called Tom and he doesn't have just the insert. I've seen his great repro fenders though!
                  Mike, I'll check with Steve at VL Heaven.
                  • Ric Bolduc
                    • Feb 2012
                    • 109
                    Thank you , Mike
                    I wasn't quite sure what you meant so I posted another picture... Let me know if you need another angle and I'll post more pics...
                    Ric
                    • 1970 XLCH
                      • Nov 2010
                      • 177
                      Thanks Ric , That answers it !!
                        It looks like the VL siren cover was held in with 4 screws in 1934, then simplified to 3 screws later. Those pesky AMCA judges are not deducting yet for this.
