Corbin Drive & Star Hub
  • wideglide38
    • Jul 2008
    • 656
    Morning,
    I'm planning to run Star Hubs on my VL project and wanted to ask if anyone has mated a Corbin Drive Hub to a Star Hub? Did Corbin make a drive tab washer that fits in the two opposing notches on the Star Hub outer thrust bearing cover? I know I will need a thin axle spacer to avoid the thrust bearing cover from rubbing the back of the axle sleeve on the Corbin drive hub. Any suggestions would be appreciated.
    William Edwards, AMCA #10035
  • marsh1915hd
    • Mar 2009
    • 297
    Yes Corbin made a drive tab washer for Harley. Buy a VL one. The Harley ones are wider than the Indian ones. The washer are spring steel and if you don't heat them to bend them they will brake.
    • wideglide38
      • Jul 2008
      • 656
      Thanks Terry. Know of a source for the VL tab washer?
      • marsh1915hd
        • Mar 2009
        • 297
        I buy the Indian ones from Greer's and bend them to fit Harley's.
