1947 Servi-Car Speedometer ratio
  • rwar
    • Sep 2012
    • 45
    What's correct? My local speedometer guru won't rebuild HDs. There seems to be plenty of used and reproduction ones around, but I don't know if I need a 2:1 or 1:1.
    Rich
  • diesel55
    • Jul 2011
    • 262
    Hello John Bordas he's the best at h-d speedo repair. 303-420-4510
      • 2024
      Rich Stock would be 2:1 - that is if you have the original drive in it.
      Jerry
      • rwar
        • Sep 2012
        • 45
        Much appreciated, thanks!
        • Sidehacker
          • Sep 2012
          • 235
          I believe, if I'm correct that 47 is a one year only speedo , and if I'm not correct I'm sure there will be many posts telling me so. Anyway if you have an original one on the bike it would be better to rebuild it. I've ran many repo speedos in my life and nothing can compare with an original Stewart Warner Harley speedometer plus it's the first thing you see when you sit on the bike and weather your doing a total restore or a runner nothing says cheep like a crappy speedo. So if you have the original call John.
