Tire recomendation
  • jeffrro1
    • Dec 2008
    • 47
    Tire recomendation
    Looking for a tire recommendation for my 1939 UL. I am more concerned about ride quality than correctness. I will eventually be running a sidecar once I find one. I have had good luck with Avon Mark II on my Indian. Would like to hear any suggestions.
    Jeff
  • vph-d
    • 1076
    If you are running 16" tires, the Avon Safety Mileage tires work well. Have a look at the Dunlop K70 tire if you have 18" rims.
    VPH-D
    • jeffrro1
      • Dec 2008
      • 47
      The wheels I am running at 18X4.50 or at least that is the size of the tires that are on it right now.
      Jeff
      • D.A.Bagin
        • Jan 2008
        • 595
        I am running 4.00x18"Dunlop K70s on my 440 and am happy with the ride. I run them at about 18-20lbs.
        • 40 Nuck
          • Mar 2008
          • 221
          I've seen the Avon Safety Mileage MkII Tire given very good reviews on many forums and have determined that I will use these tires next.
          However, I've also noticed that the designated application for the Avon Safety Mileage MkII Tire is "Rear". My assumption would be that for 30's-50's Big Twins the front and rear would be interchangeable, but wanted to know if any here have knowledge or experience otherwise.
          Also, the Coker Diamond Tread's I've used previously seem to be fine for comfort and handling, but wear REALLY fast (like 2000 miles on the rear).
          Vic Ephrem
          AMCA #2590
          • jeffrro1
            • Dec 2008
            • 47
            Thanks for the info. I ended up buying the avons and using the dyna beads to balance it.
            Jeff
