WLDD plugs
  • lightninss
    • Mar 2011
    • 6
    WLDD plugs
    Need to get a little info on what type of plug to use. I am using H-D plug 5r6a, is this the correct heat range or do I need a different plug.
    Lightnin
  • vph-d
    • 1083
    How does a long reach shovelhead 14mm resistor plug work in a Side Valve? The heat range is the same as a Pan/early shovel 3-4, but made for the 045 gap.
    VPH-D
    • lightninss
      • Mar 2011
      • 6
      Someone put an insert in the head.
      • vph-d
        • 1083
        Doh!
        The 18mm plugs were offer in heat ranges #2,3, and 4. As stated, what you're using is equivalent to a 3-4, except for the large electronic ignition gap. As a rule though, hot rod motors use a cooler plug than normal. I think an N12YC is a Champion version of the long reach 5-6. Try an auto parts store, but avoid resistor type plugs.
        VPH-D
        • lightninss
          • Mar 2011
          • 6
          So would you gap them at .025 or at .045?
          • vph-d
            • 1083
            Try .028.
            VPH-D
            • lightninss
              • Mar 2011
              • 6
              Sorry it has taken so long for me to reply. Plugs worked fine went with N12YC gapped at .028. Thanks for your help.
