34-36 VL Tanks
  • wideglide38
    • Jul 2008
    • 656
    34-36 VL Tanks
    Hi,
    Does anyone have cut-away views (construction photos or drawings) for the inside of a 34-36 VL tank (left and right)? I am trying to understand (primarily the left tank) their construction since I working on a 35 VLD project and recently picked up a set of tanks.
    Thanks in advance for the help!
    William #10035
    William Edwards, AMCA #10035
    Dear William, I'll see what I can find so please contact me outside this forum as I'm unsure how to post pictures. The left tank has a double skinned wall with two witness holes to show leaks, and this double wall is pierced on a diagonal by the hand oil pump tube. There is some serious soldering in there.
    • sswaney
      • 302
      • sswaney
        • 302
        34-36 VL Tanks
        These are pictures of a J Model tank but the construction is the same.
        • Jim
          • Sep 2001
          • 784
          Is that whole inside "tinned" with solder?
          Jim
          AMCA #6520
          • sswaney
            • 302
            Yes it is. Hot dipped in fact.
            • wideglide38
              • Jul 2008
              • 656
              Thanks for the photos Mr. B. The 'J' model explains this slight difference I see peering in the oil cap hole - I'm seeing a wire screen over the oil feed fitting and the fuel discharge nipple is further back & angled in the tank I have.
