removing lifter blocks on UL...
  • AZ pan
    • Aug 2012
    • 30
    want to remove lifter blocks on this 46 ul , someone brought up the idea of useing a slide hammer, I guess threading it into the lifter itself and slide hammering it out.Has anyone done this before? is it recommended? want to get the right tool but has been on back order for the last month. any other ideas would be appreciated.
    Thanks...
    • 4791
    Be aware that using a slide hammer causes the tappet roller to slam into the cast housing, a situation with the potential to damage both pieces. Not a good plan! Where are you? If you want to pay shipping both ways I'll lend you the correct puller!
    Robbie
    • AZ pan
      • Aug 2012
      • 30
      That was my thoughts also, but had to ask. I'm in phoenix, will look around a little more and if I cant find one I will let you know, appreciate the offer.
      Bob
        • 8247
        You are probably right Robbie,
        Even the right tool can be a problem in the wrong hands.
