Gear case cover question 30v
  • hoghead
    • Aug 2012
    • 19
    Could someone please tell me what is the purpose of the spring under the cap at the end of the crankshaft on the gearcase cover on a 30v?
  • vride5
    • Dec 2002
    • 93
    it holds a little cork washer in to keep your oil going in where it should
    • hoghead
      • Aug 2012
      • 19
      Ok, apparently that area is an inlet to the oil pump thru the hollow right crandshaft.
      I'm still trying to get a hand on this oiling system. As I haven't split the crankcase and am not sure I will at this time can somebody tell me how or where or when the oil gets into the hollow crank?
      • harleytoprock
        • Apr 2003
        • 374
        The oil pump , on the cam cover ,is driven by a cam shaft. The oil pumps to the end of the crankshaft pinion shaft end. The cork washer is held with the spring to make a tight seal. The oil then travels through the pinion shaft, then through a drilled hole passage in the flywheel, then to the crank pin. The oil then exits a hole via a hole in the center of the crankpin and lubricates the rod rollers and then flings out to lubricate pistons and main bearings. I hope this helps.
        • hoghead
          • Aug 2012
          • 19
          Thanks guys.
          That makes alot more sense than the way I was looking at it with oil coming from the hollow crank.
            That's it, and don't forget there is a shaped metal sleeve under the spring to bear against that cork seal. It makes you wonder how pre-1929 Harleys managed without oil being pumped to the crankpin. Conversely, it suggests that splash lubrication of the crank pin is probably still important in the VL.
