Servi-car front end
  • dalbydog
    • Aug 2012
    • 2
    Servi-car front end
    I have a 1960 servi-car and the previous owner swapped the front end for what appears to be a Sportster front end. I what to go back a original hydra-glide front end. Was there any big changes that will cause a "gotcha" between the front end from 1960 to later years (late 60s - 73)?
    Thank you,
    Scott
  • diesel55
    • Jul 2011
    • 262
    1960 had 1 inch timken bearings/a early sportster is 7/8 neck with 5/16 ball bearings the frames changed in 1958 for the hyd .bearing cups
      • 4791
      The standard Servi-Car fork for '60 is a fixed rake type using a version of the adjustable rake trees but with only the forward position available. The fork is the same until the end of production. You may have a Superglide fork on there which would have been a bolt on conversion.
      Other things to take into account are the nacelle unit is used with a spacer ring to adjust the headlight position. Real Servi-Car sliders have provision for an optional tow bar bracket as well.
      Robbie
      • diesel55
        • Jul 2011
        • 262
        the sliders are not different,the axle is made for the tow bar application.
          • 4791
          The left side slider is milled flat on the outside of the fender mount and drilled through for the tow bar bracket! Unique to Servi-Cars with tow bar!
          • dalbydog
            • Aug 2012
            • 2
            Thanks for all the information.
            Scott
