Where to find replacement pistons for ULH..
  • Where to find replacement pistons for ULH..
    Howdy folks,
    Rebuilding a 1940 ULH engine and need info about where to find good quality replacement pistons. Know where to get the Taiwan ones...but somewhat sceptical about these ....am I wrong beeing so..??
    Cheers
    Rino
    Light Shining Darkly
    The pistons you buy from Tedd's V-Twin won't fall apart in your cylinders. "Strutted" pistons are probably stronger, but even though I had a piston disintegrate last year, I was askin' for it, and had 13 years of solid service from my motor before I ran the livin' bejesus out of it and killed it, high speed for hours on a hot, August day. Even Tedd's pistons won't let you down; They're good, serviceable pistons.
    I suggest you ask T-bone, owner of "Bone-a-Fide Cycles" in N. Pekin, Illinois. What Tom doesn't know about this subject ain't worth knowin'. He wouldn't steer you wrong. He's in the phone book.
    Gerry Lyons #607
    http://www.37ul.com/
      ULH pistons are the same as VL ones and I've been using the strutted Taiwanese ones for a long time. The newer ones are made in China and not quite as good.
