Looking back at the original post,he says the 1939 45" fork legs were VL rigid & knuck spring fork.They are not that,they are different lengths etc.etc.
Heip with my BOUNCEY springer front end !!!
Originally posted by kitabel View Post??????????
Heat bad.
Who's "they", Lenny?
PS: What little memory I have thinks Herbert Wagner's revolutionary "Revolutionary Motorcycles..." described the 'field' adjustment performed cold, by gently depressing the spine of the frame, like with a sledge or something.
But I can't remember where my copy went.
Its all about memory.Last edited by T. Cotten; 10-12-2019, 04:19 PM.AMCA #776
Palmers. Page 31: second column first paragraph.
Talks about neck angle of 28 degrees needing to be bent out to 29 degrees while running a 16 inch wheel due to high speed wobble. Thought it might relate even though he’s working with a wl.
“They” would be Harley Davidson
They would never use heat, Lenny!
Not after they went to so much trouble to oven-treat them springy.
(Big Twins shown...)
