Servicar primary chain
  • fuzzyktu
    • Mar 2010
    • 12
    Servicars take a 96 link primary chain. Can you run a 100 link solo chain on a servi? Why the difference anyway?
  • fabercycle
    • Nov 2006
    • 243
    Kevin,
    It all depends on what motor sprocket is being used. Servi's normally run a smaller motor sprocket than a solo, thus the shorter chain.
      • 5955
      I run a 100 with a 33 tooth motor sprocket on mine. Its kinda doggy outta the hole but cruises nice.
      • len dowe
        • Oct 2002
        • 520
        What's your top speed chris? And are you dogging the clutch to the point it's trashing it? I put in a 27 tooth sprocket with a 100 link chain and i had to pull the tranny back so far that i was almost at the end. And then the rear adjusters were maxed out. I'm thinking i need to re-link my drive chain. len
        p.s.Didn't mean to hijack the thread. I figured it's good information to know
        AMCA #765
          • 5955
          Top speed is 55 MPH downhill with a tail wind.
          I am not sure what dogging it means. I release the clutch and accelerate.
