1945 U sidecar model frontend
  • Sidehacker
    • Sep 2012
    • 235
    Did sidecar models in 1945 have a special springer front end with a slightly different rake . If so what was the identifying markings.
    • 4789
    No, the forks are standard with the only addition being the sidecar inner springs.
    • Sidehacker
      • Sep 2012
      • 235
      Thanks Rubone,
      Once again you have helped. I looked all over for the info so i was pretty sure that was the case but I wasn't so positive that I would bet money on it lol. I did read somewhere that there was a special springer for package Trucks or something but not many were around.
      Thanks Keith
        • 4789
        The only "special" forks were the 2-3/8" longer versions used on some '40-'41 WLAs, XAs and TA trikes for the army. Like this one next to a standard springer.
        • otis71
          • Jul 2015
          • 597
          Did the sidecar front ends run 2 additional springs or just different springs? I was told my 45 FL should have only 2 inners total rather than the 4 currently on it but I’ve never seen a springer with only 2.
            • 4789
            There are 4 upper springs and 4 lower springs. The sidecar/Servi-Car lower inner springs are full length, not the short recoil inner springs like a solo model. All 4 upper springs are standard.
            • Sidehacker
              • Sep 2012
              • 235
              Rubone,
              . The extended forks, I assume that they only had the 45 neck stem assembly . Or did they make them with the big twin neck also.
              . Keith
                • 4789
                Originally posted by Sidehacker View Post
                Rubone,
                . Keith
                TA and XA had 1" stem. XA had 45 rockers, TA used Big Twin.
