Cast iron brake drum
  • steuerm
    • Apr 2008
    • 34
    Clarification please. I have a copy of Harley Davidsons service letter #398 that addresses updating to a cast iron brake drum on 63-66 sidecars. This is for bikes both out of the factory or as a replacement part. My sidecar is running a P/N 41409-58. That P/N Isn’t listed on that letter as old or replacement . Would this have been omitted deliberately or could it have been a clerical mistake? Maybe I’m misunderstanding something here. It’s not in my parts manual either.
    Mike S.
  • Ric Bolduc
    AMCA Member since 2000
    • Feb 2012
    • 109
    Hi Mike, What is the date of the service letter? Can you post a picture of the letter? Thanks! Ric
      • 4789
      Mike S.
      If you are getting that number off the drum it isn't a part number, it is a casting number and does not cross reference to part numbers.
      • Ric Bolduc
        • Feb 2012
        • 109
        That's correct... Casting number 41409-58A should be the cast iron version of the 1958-67 drum though I've seen cast iron versions with casting number 41409-58.
        • steuerm
          • Apr 2008
          • 34
          Sorry guys. I can’t apologize enough for not responding on this as I started the question back in May. I never saw any feedback so I slowly neglected to look anymore. I see today that there has been some input so I will attempt to load a couple of pics. and breath some life back into this one.
          • steuerm
            • Apr 2008
            • 34
            OK. If I understand this correctly the #41409-58A that is cast into my brake drum is not the HD part#. It is purely a # for some control/tracking in the manufacturing process. Im going to assume then that the actual P/N was located only on the packaging and nowhere on the drum itself. Please correct me if I’m wrong. It won’t be the first time today.
            Also ,as requested I have included a copy of that bulletin.
