wl sidecar
  • eap53
    eap53
    • Sep 2016
    • 34
    wl sidecar
    Did a wl/wla have their own sidecar or did they use the same one as the big twins? Are the mounts different? What was the letter designation for them? Thanks, eap
    • 2037
    LS,smaller body,Goulding chassis Abreth body,....mounts are different.....None of these parts are easy to find.
    • eap53
      eap53
      • Sep 2016
      • 34
      Thanks for the info. I may try to attach a 30s model package car frame. any suggestion on mounts for this? Thanks, Ernie
      • eap53
        eap53
        • Sep 2016
        • 34
        I have a 36 vl mounted on my 47 Chief. Works well except the body is for Europe with the door on the wrong side for America.
          • 8239
          I remember a run behind a 45" with a hack, Ernie,...
          Had to pass him or overheat.
          Weren't some package truck frames even wider and heavier?
          PS: Meanwhile, I've a '39 big twin frame, wheel, fender, and hookups that need a home, Folks, thanks,.. Liberty@npoint.net
          • eap53
            eap53
            • Sep 2016
            • 34
            Yes I suppose you are right. They are bigger and heavier. May have to rethink the idea. I am always interested in sidecars, why I don't know. The car on the Indian makes life simpler when you have an older sportster, an flh , a chief and a wla, the combination of shifters, throttles, clutches and spark advances on all different sides gets confusing and i forget to. put my foot down!. I may need to look for a lighter rig for the wla. May talk to you about the 39..
              • 8239
              I think my '39 would still be too heavy, Ernie,..
              And a headache to hook up.
              For a small displacement, I'd look into a little "California Flyer", "Liberty" sidecar, or maybe even wicker!
              • eap53
                eap53
                • Sep 2016
                • 34
                I may contact classic sidecars about the 29 ls repo. I do not know what they are going for these days. I may be interested in your 39 for another application. I sent you an email. Ernie
