Sidecar gearing
    • 2030
    If it fits like some of Vtwins sprockets that I have bought in recent years,you would be lapping the rest of your life to get a proper fit
      • 8232
      A diagnostic, Duffey,...
      Is rarely ever a cure.
      But you will never find one without it.
      • paddy
        • Apr 2014
        • 219
        Ok well so now I know I am not alone. I do not have access to clover. But the key has side play in the vtwin sprocket that I can see it moving side to side inside this brand new POS sprocket..Also this vtwinn sprocket sits proud almost 3/64. Compared to the sprocket that was on previously. PBI only make the trans sprocket for the our old Iron. So I guess I am in search of another manufacturer or hopefully another member may have a nos engine sprocket .
          • 8232
          I guess I was showing off suggesting Clover compound, Paddy!
          Any auto store valve grinding compound should give a contact-patch reading.
          Once again only for a diagnostic, Comet cleanser could do if you are attentive.
          I only suggest this inspection to determine more about the repop's defects, because ultimately all catalog repops are just raw materials.
          • paddy
            • Apr 2014
            • 219
            Ok got it but is not the key way issues unsolvable? Ultimately play in the key way is not good correct?
              • 8232
              If the key were all that keeps the sprocket from spinning, Paddy,...
              It would shear even if it were a good fit.
              The tapers hold the sprocket; That's why you have to shock them for removal.
