the first Harley's
    • Mar 2003
    • 1052
    #271
    redlands cal. 1909
    maybe the motor belonged to this fella
    www.motorcyclecannonball.com
      • Feb 2003
      • 5353
      #272
      That's the first time I've seen one surrounded by palm trees!
      Cory Othen
      Membership#10953
      • silentgreyfello
        • Nov 2006
        • 861
        #273
        Oh, to be able to walk back into time 100 years, just for a while anyways! Nice photo. This is evidence of the first TT racer by removing the fenders!
          • Mar 2003
          • 1052
          #274
          yeah ,cory and jim this is a favorite strap tank picture for sure.the more i look at it the more i like it. you have a fenderless strap tank ,not unlike the 1905 line drawing ,yet it is an 8 bolt. probably the end of an era for the company , as is 2221. yet it still has the undenieable lines of a stripped down harley. i'd think such a large motor in a fairly light chassis would rock and roll.
            • Mar 2003
            • 1052
            #275
            Originally posted by silentgreyfello View Post
            I'd stamp the carb in a heartbeat if it were mine. It is not the vin number, and not on the cases. If you don't stamp the carb, some blowhard will cut it down for not being stamped. Lonnie, I have a list of the original bikes vins and their respective carb numbers. There isn't a real pattern, but if you want it, let me know.
            thats a good idea,i'd like to post the pics of the remaining 8 bolt engines and try and discuss the differences.especially the carbs ,and fins on the later 08 cylinders.appreciate any input.
              • Mar 2003
              • 1052
              #276
              here's a picture of 1835. the grandaddy of all 8 bolts.as far as anyone knows 1835 is the earliest harley vin number in existence. no belly numbers,but the vin was stamped both on the cylinder ,and the case as well as on the face of the exhaust port on the cylinder.a cylinder that has 17 fins .this engine was discovered missing its cam cover and timer ,and carb. at first believed to be a 1906 ,but most experts think now that it is most likely a 1907. one of only 2 1907's known.it was resurrected using the early six bolt type gas/oil tank ,and the sager type attachment to the common rigid fork,as opposed to the standard 1908 sager fork..1907 documents and advertising prove that 1907 was a year of transition with the early six bolt chassis housing the larger 8 bolt engine. i think 1835 has been put back to the best of our abilities to what it probably looked like in 1907. other than the fenders.
                • Mar 2003
                • 1052
                #277
                may 4 1907
                this early ad tells some of the story .its from may 4 1907 .it has the early style six bolt side fill gas tank, and the sager type attachment on the rigid fork. powered by an 8 bolt engine though.i think it also has the smooth earlier fenders .
                  • Feb 2003
                  • 5353
                  #278
                  That machine is pretty darn awesome! I like the way you incorporated the transitions. Were there actually any eight-bolts produced in '06? Oh, while I'm thinking of it..... I'm trying to remember if you posted anything on what you decided to do with the "Florida" bike. I'm thinking you may have finished it but I can't recall for sure.
                  Cory Othen
                  Membership#10953
                    • Mar 2003
                    • 1052
                    #279
                    • silentgreyfello
                      • Nov 2006
                      • 861
                      #280
                      Lonnie, can you post more photos of the '07? I'd like to see the left side and the Sager attachment. It turned out very nice!
                        • Jul 2003
                        • 1832
                        #281
                        That is great documentation. It beats the odds as most '08 Harleys were sold in the Milwaukee-Chicago area. This may be the very bike at that. Nice!
                        Herbert Wagner
                        AMCA 4634
                        • Barry Brown
                          #282
                          That is friggin' beautiful workmanship ! I'd like to see the other side as well.
                            • 5955
                            #283
                            I notice in all the old photos I see of early machines that they don't appear to have brightly polished cases and plated barrels. So how come all the restorations do?
                            • silentgreyfello
                              • Nov 2006
                              • 861
                              #284
                              Those cases in the old photo look pretty polished to me. The cylinders do not in the photo. However, the cylinders were nickel plated from the factory. Here is a late '08 in orig trim. Looks nickeled after 100 years, and still shows a little shine.
                                • 5955
                                #285
                                That appears to be dull nickel wash, not bright nickel plate.
