Another Schebler carb ID
  • FLFD7
    • Feb 2021
    • 739
    I have another Schebler carb marked DLX-4…any clues as to what it fits (apologies if it’s not pre 1916 and probably from the 20’s but I don’t know where else I should put this post). Bunch of pictures follow…
  • FLFD7
    • Feb 2021
    • 739
      • 8239
      Another beauty, Joe!
      My listings call it for the 61" Chief, probably for a few years.
      Somewhere your father stashed all the airhorns.
      PS: The horseshoe float is probably correct.
        • 8239
        Who knows what this is, Folks?
        Most Type As have no such bump, or whatever is screwed into it.
        I have encountered one DLX14 with a similar casting, but nothing machined into it.
        A clue may be this unique airhorn...
        Stamped DLX4, but no bump!
        • FLFD7
          • Feb 2021
          • 739
          Cotten,
          It’s a spring loaded pin, I can push it in and it pops out…I don’t know how a cover would attach…
          Another mystery. My father was collecting this stuff since the 60’s, he never had bikes this early except a 23 Chief project he’s been gathering parts for 20 years for that one. I remember going to meets in the seventies and my father would buy a whole box of carbs, these early ones just happened to be in there.
            • 1675
            ...that cover appears to work as a choke, and could be attached via two screws where the choke shaft could've been, and if all that speculation is anywhere near reality then the spring loaded pin could work as a detent to the rotating air baffle. That's all I got.
              • 8239
              We appreciate your father's legacy, Joe!
              I found another pic of the curious bump, and I believe this one remained frozen because it had nothing to do.
              Did I miss any air passage behind it?
              Type A DLXs had airhorns with separate choke assemblies, held to the body by two tapered-head screws, and there was a variety:
              (DLX12)
              (Weird DEX17 stamp in the wrong place..)
              (DLX10 snoot; Note thumbtab is indexed from twelve o'clock to three o'clock by the screwhole next to it..)
              • Tom Wilcock
                • Jan 2008
                • 333
                Schebler 1925 manual supplement 001.jpgSchebler booklet 001.jpgSchebler booklet 2 001.jpg Here is a supplement page from my 1925 Schebler service station manual. It has some carbs that are not listed in the 1928 edition.
                also is a copy of a Schebler sales booklet showing the airhorn with the choke disc.
