Indian 1911 Tires
  • American X
    • Feb 2012
    • 35
    Indian 1911 Tires
    What is the correct tire size for an Indian 1911 Single: 28 x 3 or 28 x 2 1/2?
    Thanks for response
  • Tom Wilcock
    • Jan 2008
    • 330
    1911 used 28 x 2 1/2 tires. Tom Wilcock
    • American X
      • Feb 2012
      • 35
      Thanks Tom, the leaf spring is touching the tire slightly. I have the correct tires fittet. I think you order a book. Its on the way
      • Tom Wilcock
        • Jan 2008
        • 330
        I look forward to receiving the book. I don't know if the spring links varied in length for different years. If they were too short then the tire would touch. I will check the length of them on my 1911. Tom
        • Tom Wilcock
          • Jan 2008
          • 330
          The spring links in my 1911 project pile are different lengths. One is 14 3/8" (305mm) and the other is 15" (383mm). I would assume the short one is correct for 1911 as the fork is shorter than my 1914 fork. Tom
          • Tom Wilcock
            • Jan 2008
            • 330
            The measurements I gave are from the center of the bottom hole to the center of the lower spring hole at the top. Tom
            • American X
              • Feb 2012
              • 35
              Mine is 16,53 inch (415 mm) from the center of the hole at the rockers to the upper spring hole at the top. If I measure the lower hole where the spring is fitted, it is 14,80 inch (376 mm)
              My fork is original as the complete bike. May be they offered different wheels. I have not read anything about it.
