Brake drum identification
  • Brake drum identification
    Hi. A few years ago I recieved a brake drum that came in a box of Harley parts.
    It is not Harley, but I would like to try and identify the origins of the old part.
    In my initial enquiries to british fans I was told it may have been early Norton but have drawn a blank on any further identification. Can anyone identify the drum from the attached pictures. It is 18 spoke. 125 mm diameter X 25mm brake width.
    I receieved the following advise from a one local British motorcycle shop:
    The use of a needle roller bearing inside make me think it is European rather than British
    Thanks.
    Steve.
    Steve Little
    Upper Yarra Valley. Victoria.
    Australia.
    AMCA member 1950
    Steve,
    Where's the picture?
    Robbie
      Hi. I have tried to load the pictures 4 times but it wont do it for some reason. I will get the young bloke who works for me to have a go.
      Regards Steve
      Steve Little
      Australia.
      AMCA member 1950
        I sent you a pm Steve.
        Cory Othen
        Membership#10953
          Cory Othen
          Membership#10953
            Looks like a Harley lightweight drum. Hummers used needle bearings like that in the hubs. And they use 36 spoke wheels.
            Robbie
              Here's some hub pics that came from e-bay....
              Cory Othen
              Membership#10953
                Cory,
                The one you posted has a speedo gear on it. The true "Hummer" had a speedo optional and used a needle bearing hub for several years. The first year '55 hummer did not even have a front brake or provision for one! The earlier and later models other than the Hummer hubs all came with the speedo gear on and most were ball bearing both sides. I can provide parts book illustrations if needed for the needle type.
                Robbie
                  Close but no cigar eh Robbie?? Thanks for the clarification. I'll likely know what I'm looking at now if I see one on a swapmeet table.
                  Cory Othen
                  Membership#10953
