Motor ID help needed
  • BigLakeBob
    • 2767
    My friend finally acquired the motor from the barn finder. I'll attach more pics. Bore looks real nice and measures 3.993". Stroke 3 3/4". Spark plug is 1/2-14 NPT. There are threads on the intake tower to possibly hold a carb. The exhaust port ID is 1 1/2". Of the three mounting lugs on the case only two are threaded 3/8-16. The cam is a two lobe which appears one is for the ex valve and the other for an oiler. The head is removable with a 'sub' plate between the head and cylinder top. Any help appreciated. My friend will have it at Wauseon looking for info.
    Bob Rice #6738
    • BigLakeBob
      • 2767
      Bob Rice #6738
      • BigLakeBob
        • 2767
        Bob Rice #6738
        • BigLakeBob
          • 2767
          Bob Rice #6738
          • BigLakeBob
            • 2767
            Bob Rice #6738
              • 6018
              I have to wonder if someone modified the atmospheric valve chamber for some reason. Otherwise, I can't see how it gets it's fuel/air charge. This picture of a Raycycle single shows the intake manifold enclosing the intake valve chamber, and also sealed the intake valve cage into the cylinder. I don't see how Bob's friends engine could work as it is currently configured.
                • 6018
                I was going to add, I think that engine shows high quality pattern work, and good engineering, but I would be surprised if it was earlier than 1908. Very unusual to see a quality motor with no markings, or 'cast-in' name, and a removable head.
                • Tommo
                  • Sep 2001
                  • 1320
                  I'll throw this into the ring and say it looks like it has been modified for use as an air compressor
                  Peter Thomson, a.k.a. Tommo
                  A.M.C.A. # 2777
                    • 6018
                    I'm sure you're right, Peter. Wish more people had made compressors out of early motorcycle motors instead of scrapping them out.
                    • pem
                      • 700
                      When I interviewed Perry Mack's son Bill he had a single cylinder 1913 Mack Motor his dad converted into an air compressor. Last time I saw it it was used in a "Fantasy Bike". It was polished and plated and in my opinion ruined. The only single cylinder Mack Motor I had ever heard of.
                      • Tommo
                        • Sep 2001
                        • 1320
                        I saved my E.R.Thomas motor from being coverted into an air compressor.
                        It was fitted in a rotary hoe and had been replaced by a Briggs and Stratton and the owner was going to make an air compressor out of it.
                        I swapped it for an Industrial JAP motor
                        Engine number 878
                        For whatever reason the site won't let me upload images any more so no photos for you to see.
                        A.M.C.A. # 2777
                        • Tommo
                          • Sep 2001
                          • 1320
                          #27
                          A.M.C.A. # 2777
                          • BigLakeBob
                            • 2767
                            #28
                            Thanks for the comments and feedback. My friend has it at Wauseon now, I'll report back if anyone there can shed some light on what it is.
                            Bob Rice #6738
                            • BigLakeBob
                              • 2767
                              #29
                              Seemed to have been determined not an atmospheric intake valve but cam operated, about a 1/4 inch lift. With such a large bore possibly used as a bicycle racer pace bike.
                              Bob Rice #6738
                                • 6018
                                #30
                                What a lousy detective I would make. I didn't notice the intake pushrod guide. Apparently no leads about it's origin, or maker at this point.
