Excelsior frozen in time
  • Stein.S
    • Sep 2021
    • 57
    #31
    This gallery has 5 photos.
    • Stein.S
      • Sep 2021
      • 57
      #32
      • Stein.S
        • Sep 2021
        • 57
        #33
        Filled the cylinders with a mix of kerosene and 2-stroke oil. After a while it came loose without using force…
        Before loosening I checked the inside of the cylinders with a camera. There was no rust.
        Next step is to fill pure oil into cylinders and turn it.
        Spark cables are not in a good shape. Will have to change them. Do not know if it will be needed to remove the magneto to get access.
        I do understand that my knowledge here is low. Have seen the 1921 maintanance book at the AMF library( got a tip about it here) Do anyone know if there is any detailed information about the engine somewhere?
        Regards
        Stein.S
        • Stein.S
          • Sep 2021
          • 57
          #34
          Do anyone know how this tower is supposed to be opened?
          This gallery has 1 photos.
          • bernhardt
            • Dec 2007
            • 67
            #35
            Be very careful!! The pick up is Bakelite and will easily shatter or break. It looks like you pulled the brush and spring out of the tapered end of the pick up . Now look into the hole - you should see a small slotted set screw. Back the screw out a few turns, and it should release the spark plug wire. Put all of those little parts in a plastic bag or a jar - they are impossible to replace.
            A. Bernhardt
            AMCA# 9726
            • Stein.S
              • Sep 2021
              • 57
              #36
              Thank you for answering.
              It seems like the set screw had the slot melted away.
              I bought new towers for Bosch magneto. Good to know that this ones is not possible to buy. Will have to be extra careful then.
              think first step will be to try removing the cable piece by piece. If I can get it out, maybe lubricate and try to drill a small hole in top of the setscrew and see if a torque bit might get hold enough for getting the screw out.
              Edit: None of the two cables was attached under the set screws. One was glued to the bakelite and the other one was loose. The set screws missing slot have been a problem before….many years ago…
              its a too big risk to drill in the set screws, so think best solution is to use a bit of glue and maybe use spings from a ballpoint pen between the set screws and the cables.
              • Stein.S
                • Sep 2021
                • 57
                #37
                Magneto. After a clean up the magneto gives sparks. The bearing at the sprocket side is in a very bad condition. The inner ring is also stuck, and there will be a need for a new bearing. Do anyone know the type of bearing? Would like to order one but its difficult to measure without getting the inner ring off the axle.
                The timing. It is possible, because of the damaged bearing, that the timing was off because sprocket slipped. There is two markings at the sprocket for magneto. The only information I have is from the handbook for 1921 model. From the AMCA library (Found that one after a tip in this forum thread) However, the one in the handbook shows a sprocket with one mark only. Because cylinders is attached to the engine, it is a bit difficult to measure distance before top dead center. Managed to find tdc for both cylinders by using camera. The timing as it was seems to be a bit early? Do anyone have a picture with markings that show the timing for this motor? With the Berling magneto and two markings at the sprocket?
                Best regards, Stein-S
                This gallery has 4 photos.
                • Stein.S
                  • Sep 2021
                  • 57
                  #38
                  First it was the Berling magneto who would not give sparks. Then the magneto was sent for overhaul in autumn 2024. Then I tried a Bosch magneto. Got it to start, but probably missed with a tooth when setting the timing. Waited for the Berling magneto to be finished.
                  Got it back from overhaul this autumn. This is the first start where the engine is running clean with fuel through the Schebler. Probably first time running clean since 1940.
                  Tried to upload the video from the ipad, but failed bacause "mov" was not an accepted format…. Hope the dropbox link works.
                  https://www.dropbox.com/scl/fi/ooqsqp40thc7r3mtuffhf/IMG_8314.mov?rlkey=x7pvhjq67pvihq3vap2sj2dnb&st=ti bz2s1y&dl=0
                  • joe fxs fxr
                    • Dec 2020
                    • 702
                    #39
                    Yes that works. Good job, it sounds great. What's that foot thing you did?
                    AMCA #41287
                    1971 Sprint SS350 project
                    1972 FX Boattail Night Train
                    1972 Sportster project
                    1973 HD Golf Cart project
                    1989 Springer Softail project
                    2020 Heritage Classic 114
                    • Stein.S
                      • Sep 2021
                      • 57
                      #40
                      Its the the opening of direct exhaust outlet. When closed exhaust goes through the muffler/silencer, when open it is direct outlet and a lot more noisy…Probably to lower noise when being in populated areas, and when at highway it could be open, with less heat in engine and maybe more power….
                      • joe fxs fxr
                        • Dec 2020
                        • 702
                        #41
                        Aha, a factory installed cutout. Cool bike, enjoy riding it
                        AMCA #41287
                        • Stein.S
                          • Sep 2021
                          • 57
                          #42
                          I have a problem with rear cylinder misfiring and throwing oil. I think it might be that I pump too much oil into the crank case? I measured, and had 1 dl of oil when I empedied the crank case through the draining in the bottom of the crank case. When I read in the " instructions for care and operation for Excelsior series 21" it is mentioned that after flushing with kerosene you should give a pump ( one?) with the hand pump. I pump like 4 pumps to get 1 dl. How much oil is supposeed to be in the crank case?
                          I have not been adjusting the individual oil supplies to each cylinder. I guess nobody adjusted since it was used last time, and I think that even if one of the individual oil supplies was adjusted to take more of the oil from the pump than the other, it should not cause a problem with throwing of oil. I guess it is too much oil in crank case, and that the rear cylinder get most of the oil thrown up into the cylinder because of the direction of rotation. I am a bit scared to test with a very low amount of oil in the crank case without having information about the amount of oil that is supposed to be in there…
                          Do anyone know something about the issue?
                          added: Video first ride since probably 1940
                          regards
                          Stein.S
