I have a friend that placed his M/C in the show last year as a junior entry. His score was 99 & 1/4 point. Not bad for his first try. This year the same bike UNCHANGED and exactly as the year before did not receive enough points to be mentioned. Whats up with that. When the judges were questioned after the awards were handed out there was a question on the rims if they were correct for the year and acording to the judges that were present it was a toss up. Naturaly the judge that made the point deduction had left for the day. How convienent. As to the remaining judges they buckeled under question and gave the points back so the owner was in the winners circle. If at all they should have stood there ground in my opinion. Not that I didn't want to see it corrected but that shows if you squeek you get the grease. Piss poor judging at its best. Why is it if the judges are unsure if the part is correct the first thing is to deduct points ? It should be the other way around. Substantiate your veiw then deduct points and if you cannot substantiate your veiw then NO deductions. Enough of my venting on the judging.
It would have been nice if the Sunshine chapter could have set a booth or table so new commers could get some info when arriving. Nothing of the sort was set up that I could find and as a result I was unable to get my ride'em and display'em pins as stated in the spring issue for the meet.
Is there any way the web site could post a itinerary for the meets ? As a member since Feb. 03 I have only received my third magazine so I do not have anything to refrence to for info.
I thought there are 4 issues a year? Seems I missed a few. I might be better off spendind my money else where.
