Fuel Proof Black?
  • Mr. Big
    replied
    Mr. Big!
    Sorry for this late reply,
    but it seems like your post just now appeared out of no where....
    Schebler's later potmetal models were an admirable gloss that survives the decades, and quite resistant to modern fuels as well.
    Linkert bodies were less glossy, but that is a subjective observation clouded by the fact that they were a rough bronze casting, and most often it did not survive.
    I would settle for any gloss black that is as fuel-resistant as VHT, but more resistant to fingernails. And convenient to apply. And readily available to all for touch-ups.
    That's asking a lot,
    Hey thanks, Cotten. Is there a particular VHT product you use? I saw quite a few on their website. And what do you use for bowls?
  • bmh
    replied
    Etched steel will have to be used for my comparison of Seal-Lock and JB-Weld this year, however, as Seal-Lock depends entirely upon a molecular bond.
    That's why I was wondering about the glass for some of the other things. Been using an epoxy primer that is supposed to have some molecular bonding properties. But I see you are on top of it. I will wait to hear your results.
    replied
    Originally posted by bmh View Post
    And if I may, I'm curious. Why peices of etched glass and not small squares of brass or copper?
    Brian!
    Of course 'you may'!
    This is all about questions and information.
    I chose glass because it is inert, compared to metals.
    I am studying the effect of my local gas upon paints, sealers, and adhesives, and the effect upon metals would add a variable. (Note the brass in my attachment).
  • bmh
    replied
    Thanks for the warning on the pot metal carbs, I will not need to learn that the hard way now. And yes shipping on hazmat stuff is out of hand. I forgot about that. When I buy parkerizing solution it's a gallon at a time which lasts me a good while. Last time I ordered the shipping was actually more than the product
    replied
    Michael!
    Do not be sorry!
    This thread is all about exploring alternatives and testing them.
    You have helped us all with your observation.
    I thank you again!
  • Paquette
    replied
    Cotten--Do not bother with this product. I just put a bit of Shell 87 oct. on a piece of metal that I had painted about 2 weeks ago, sat in the "baking oven" that is part of my upstairs shop and it removed the paint faster than lacquer thinner. I am trying to learn just to post about things I know about, which is very little--Sorry--Michael--6671
    replied
    Originally posted by Paquette View Post
    Tom--I have not tested this with fuels ( as I have no real reason to do so) But I have used a Rustolem High Temp paint that the label states is gas and oil resistant. As I said I have not tested it but it does give a nice finish--Michael--6671
    Michael!
    "Hard-Hat" Rustoleum was suggested to me a few years ago with great praise.
    P4gas ate it for lunch.
    I've still got most of the six-pack left.
    Admittedly it is not the high-temp formula, so I shall seek it out, hopefully in a smaller minimum order! And also hopefully in something other than barbeque black, as most high-temp blacks tend to be.
    Thanks for your suggestion,
    replied
    Brian!
    Baking is fine for bronze Linkerts, but I found out the hard way that it is not good for potmetal Scheblers. The real hard way.
    (Guess why DLX113s are the most expensive cores on the planet, and the most expensive to refurbish: they caught fire off the ignition below them.)
    At twice the price of VHT (without the other preps), it is still within consideration. (Whoops! Three times counting shipping. It will cost me nearly $40 just to test a 6 oz. can, hopeing that it will survive conditions for which it was not designed.)
    Although 350F would guarantee tragedy, 180F for three hours might mean that extended time at a lower temp would do. Considering Flatty temperatures, it is amazing that potmetal Scheblers survived at all.
    On to testing, please note that I use etched glass plate: ALOX-blasted for a mill profile.
    Part of the plate I leave un-etched for comparison. (And a spot I can engrave for labeling.)
    The fact that VHT's epoxy is so P4gas resistant is why I maintain hope that there is a superior coating.
    Thanks for searching their site for an aerosol, as I couldn't find any!
  • bmh
    replied
    Cotten, I see where you get the $75 for the duracoat, did you look at the durabake? at $25 for a 6 oz aerosol can it doesn't look outta line to me. Especially if it works. Note that it must be cured by baking. Clear-coats are optional.
    http://www.lauerweaponry.com/item-de...TOKEN=44682412
    I must also ask this. I saw in another post that you were testing samples of something on plate glass. That is not the way you are testing the paint is it? As they make the solvent package more polar bear friendly, coatings are becoming increasingly dependent on a mechanical anchor. The surface must be rough enough for the paint to get a good grab and needs to be free of any oxidation as that forms a boundary in your coating. Used to be the solvents would bite through slight oxidation, that's not the case these days. Honestly I don't think you're gonna find anything in an over the counter rattle can that's going to hold up to modern fuel. With the exception of hi-temp paint for cylinders and such I don't use anything from a rattle can on motorcycle parts, and I'm looking for a way to get away from those also as they just don't seem to have the durability they did some years back. Mixing small amounts of epoxy or catalyzed finishes is not the big deal most make it out to be. A Preval spray unit for $7 would probably have enough propellant to do 20 carbs, the bottle is already marked in ML's so its real easy to mix little amounts. Turkey basters work well for metering out catalysts and reducers. We use these at work for small samples and field touch ups and I've begun using them here for the small things that aren't worth dragging out all the spray equipment.
  • Paquette
    replied
    replied
    Originally posted by Mr. Big View Post
    Palmer's sez that the Linkert for mine should be black but just says "dull". For the VHT epoxy you mentioned, which "black" product do you buy for that "factory" look?
    Mr. Big!
  • Chris Haynes
    replied
    Originally posted by indianut View Post
    Black Oxide is cheap and easy. I don't know how well it will take the fuel, but I'll bet pretty good.
    Are you talking about Black Oxide metal finishing? I don't know it that would work on brass. Besides it would not look at all like paint.
    replied
    Indianut!
    The problem with black oxide is that it doesn't look anything like L&L or Schebler carburetors' lacquers.
    The AMCA judges would be pointing their stink-fingers in disgust.
    Thanks for your reply!
  • indianut
    replied
    replied
    Brian!
    From what I can gather about the cost, and the additional labor and solvents to apply it,
    I would have to charge $75 a carb to break even!
    And if it is so durable, why do they prescribe a surface protectant to go over it?
    I'm afraid I'll shop a bit more before I invest $50 just to see if it is P4gas resistant.
    I would really like to stay away from anything I must mix and airbrush, as not only is the labor tripled, I must stack carbs up to do them practically without a lot of wasted mix. Been there, done that with Aerogloss over Variprime. (And P4gas ate that.)
    I appreciate your reply, though!
