I need to locate and drill the saddle bag holes , side fender trim ,and front fender light in my fenders on my 40 knuckle project. Any help with a template or measurements would be appreciated. Thanks, Paddy
5 hole saddlebag ,front fender light and side trim hole locations
Rollo I had come up with this quote while doing my research. It also says that in the Palmer Guide....."According to research done by Michael Paquette (Worsham Castle) all '47 models through serial number 10050 were 5 hole and changed to 4 hole after that.
Robbie."
Every original 1940 I have seen has 5 hole saddlebags.
Jerry
Originally posted by Rollo View PostI believe your 40 should have 4 hole bag mounts to be correct. Ought to double check that. If you are using them because that is what you have then so be it. Good Luck!
Tom (Rollo) Hardy
AMCA #12766
