Hi Fi Blue Where to buy?
  • cmcadam
    • 23
    Anyone know the paint code for Hi Fi Blue, and its silver base? Or where to buy it?
  • sirhrmechanic
    Vigilis
    • Dec 2010
    • 1147
    You won't be able to buy the color from any 'standard' paint producer as a premix. There are, from what I understand, some folks doing mixes. But not sure anyone shares actual paint codes or that there is a precise mix.
    Your best bet these days is to use a modern paint finish such as Centari, Chroma, etc. Hi Fi Blue would have been single stage, so the Chroma Premiere system would give a very accurate representation vs., say, a clear coat.
    A good paint shop will have color books that you can use to match or you can have a good paint supplier use a Kollmorgen machine (paint laser matching... generic term) to match a sample if you have an original sample of Hi Fi Blue.
    I had my EL tank done last year in Flight Red, Chroma Premiere. It came out perfectly. They matched it with laser. One of the reasons I went with the Chroma system vs. buying pre-mix paint is that my paint shop could ensure it was compatible with the primers/fillers, etc. and would 100 percent stand behind the paint job. Buying a can of hi-fi blue with unknown chemistry makes it really hard for your painter. And they may not warranty the job.
    Just some rambles. But been to this rodeo a few times.
    Cheers,
    Sirhr
    • upsrod
      • Feb 2010
      • 320
      It is a candy blue with a silver base coat.
        Hold on to your wallet, Between Etching primer, workable primer, silver undercoat, candy blue and the birch white you’re looking at $500 clams just in supplies. John Pierce has everything you need but get ready for the restorer butt reaming. Bob L
        • len dowe
          • Oct 2002
          • 520
          John Pierce is the only place to buy paint...Anybody else is just an imitation.
          AMCA #765
