Originally posted by exeric
View Post
Thanks Eric! Here is the finished work. 20250111_032216.jpg 20250111_032314.jpg 20250111_033914.jpg 20250111_032247.jpg
I'll bet you're itching to put those tanks on, Steve
Looks great, you do excellent work.
It's been awhile, but now we're getting very close to the finish line! 1000013519.jpg 1000013518.jpg 1000013516.jpg 1000013543.jpgAttached Files
Frank's new coming out party includes her new name, Frankie!!! Tool Man Tim gray primer to Betty Boop Electric Blue Pearl! Tanks, fenders, etc, will be Butane Blue Metallic which is actually a gray with a subtle tint of blue.
Oooh the fun begins, it's going to look like a motorcycle soon!
Frank's apart, ready for new paint. Yesterday, i bead blasted all the large parts. A few days ago i ran all the small parts through the cabinet blaster. Today, i took the parts up to my friend who's going to do the paint. The paint scheme will be 'ten's-'teen's era grey for tinware, frame, forks, etc, will be a dark blue. Have yet to decide striping colors. We're trading work. I'm going to get his 1970 Triumph 650 Trophy running which will include an engine rebuild and going through the chassis so it's road ready.
Gene, if factory engine and rear wheel sprockets are used, this 1936-only 4-speed's Low gear is slower than the 3-speed. Second and Third are evenly spaced. High gear goes no faster than the 3-speed's High gear. i have an 18t engine and 41t rear wheel sprockets, so the engine comfortably motors down the road at 55 mph. Third is really nice in the hills.Originally posted by Steve Swan View Post
Hi Gene,
Great to hear from you and my best wishes to you and yours for 2023.
Re: the 4-speed, my knowledge of anything other than the '26 through '29 J-type machines is pretty limited. As i understand it, the 4-speed gears are 1936-only fitted into the JD case with the 1936 cover cast in brass as again, from it's been explained to me, another very difficult to find one year only part. As i understand it, the 1936 case was fairly similar to the J-cases which makes the conversion using a J-case possible. I don't know the ratios, but i will ask, as it would be good to know and to compare to the 3-speed transmission. As far as High gear being an overdrive, it doesn't feel like that, but i need to get some honest miles on the rig to form a more accurate impression. The picture of the shift gate isn't very good, but the shift pattern is 1-N-2-3-4. I'll follow back on the ratios once i learn more.
Hi Gene,Originally posted by gharper View PostSteve,
Nice job! That is very interesting that it cruises at such a high speed and is happy there. Curious what your final gear ratio is.
So I can understand what's going on inside the new gearbox: Is this a 3 speed with an overdrive? I suspect so because you mentioned new 3rd gear is similar to the old high gear. Interesting that the shift pattern is 1-2-N-3-4, like the ill fated 39 transmission setup which was abandoned after 1 year. Is that an odd setup to shift through?
Steve,
Today, we had temps in the lower-mid 40's, so i took a quick test ride with Ray Bartomeli's new 4-speed conversion and WOW! What a positive improvement! Evenly spaced ratios between gears and a lower Low and a higher High! Albeit my ride was less than 2 miles, i was able to get things moving to just below 65, so Third in the 4-speed felt like High in the 3-speed, basically around 50+ mph in Third in which 50-55 was an engine-happy highway speed with the 3-speed, so High in the 4-speed seemed like 60+ was at the least a happy speed for the engine. Eventually, I'll be moving down to a 41t on the rear wheel from a 43t which should make 65 mph easily and comfortably sustainable. Shifting was smooth and positive and quieter than the 3-speed. For going straight out on the road for the first time after setting up shifting on the lift, for the most part Low and High felt positive. On the repro gate, i filed away on the front as far as i dared, i still have another 1/8" i can remove on the rear, so i believe i can get just a little more shift lever movement to make Low and High thoroughly positive. I would like to find an original factory clutch release lever for the 4-speed transmission. Once weather is warmer, i will take Frank out for our 60 mile route.
You'll also note Frank now has 3 eyes; i may have to change his name to Polyphemus the Cyclops who was a Greek god with a 3rd eye...
20221123_213956.jpg20221107_155203.jpgLast edited by Steve Swan; 12-31-2022, 10:57 PM.
Thanks Rich! Yes, good stuff. I'm already envisioning in my mind how the swap will go. pretty sure i won't be able to wait more than a year to give Frank this treat, so probably be nice winter project; one of the things about the J-bikes, so simple and straight forward. The gate is what is used on 1936 models, as i understand it, first year for the 4-speed.Originally posted by RichO View PostSteve, What's the solution on the shift gate (3 to 4) ? Inquiring minds need to know. That transmission looks like m/c jewelry. Cool beans!
20221124_094635.jpgLast edited by Steve Swan; 11-24-2022, 10:18 AM.
Well, i'm excited. Ray Bartomeli built me one of his 4-speed's in a '27 JD case. Ray's trademark is the bronze cover and clutch arm. Not sure when i'll make the swap, maybe this winter for next year's riding , but i am also thinking of waiting until next year at this time, as i hope to tear Frank down for some shiny paint, but that seems like a long time to wait...
20221123_213956.jpg20221123_213946.jpg . 20221123_191814.jpg20221123_191718.jpg
