38 Indian Chief
    • 970
    Nice fix.I am now wondering if the set I recently ordered,also 38,will have the same issues.
    I thought I could use a set of 52-53 orig. brazed tanks that are on the self with some small tabs to fill the gap for the smaller dash but apparently the seat post bolt sits about 1/4" higher above the frame tube in a plunger frame and the tank mount tabs would have to raised to lower the tank to clear the seat mount.
    What happened to the rear trans mount?
    • Bills37
      • Jan 2010
      • 247
      It got trimmed off at some point, I have no idea why. I'm going to fab a piece to replace it.
      • Bills37
        • Jan 2010
        • 247
        Did a little electroless nickel plating. Tried this before with less than perfect results. Parts after they ere glass beaded.
        • Bills37
          • Jan 2010
          • 247
          Next they get boiled in an alkaline solution and wire brushed to remove and oil or other contamination.
          • Bills37
            • Jan 2010
            • 247
            They're in the soup now. This is part art & science trying to estimate the square inches and the mix of chemicals.
            • Bills37
              • Jan 2010
              • 247
              I was pleasantly surprised when I pulled the parts out of the pot.
              • Bills37
                • Jan 2010
                • 247
                  • 6039
                  Your parts came out beautifully, Bill. I've used the Caswell electroless kit a number of times and have been quite happy with it. There is no doubt that a professional plater will do a professional job, but I like the convenience of keeping my parts at home, and having control over the amount of plating, and texture.
                  • Shaky Jake
                    Ol' Poop
                    • Jan 2013
                    • 261
                    Electroless nickel plating? Why did I not know about this? I'm interested in learning more!
                    Kevin
                    Kevin
                      • 6039
                      These are ABC generator parts I did for my Henderson, using the Caswell kit. Sorry for the detour, Bill.
                      • Bills37
                        • Jan 2010
                        • 247
                        No worries exeric, it's all about sharing info & experiences. I used the Caswell kit too. My first attempt was something of a disaster. I didn't replenish my chemicals properly. Oh well, you live, you learn. Your parts look great. I'm looking forward to doing more hardware and other parts for the engine next.
                        Shakey Jake check out Caswell Plating at http://www.caswellplating.com/
                        They have all the kits & ingredients for all kinds of plating.
                        • Shaky Jake
                          Ol' Poop
                          • Jan 2013
                          • 261
                          #27
                          Thanks Bill. I've used the Caswell gas tank sealer a couple of times, but I bought it locally or on Amazon, so I never knew they had a website. It looks like they make all kinds of stuff.
                          Kevin
                          Kevin
                          • Bills37
                            • Jan 2010
                            • 247
                            #28
                            This isn't too exciting but I'll show it anyway. As many rigid frame Indian owners know the sidestand is a poorly designed afterthought and find one that the arm is not broken off is rare and expensive. So I thought I would make a stab at repairing one. I have a repro that I can use for a pattern for templates
                            • Bills37
                              • Jan 2010
                              • 247
                              #29
                              Rough cut the pieces out on the bandsaw.
                              • Bills37
                                • Jan 2010
                                • 247
                                #30
                                After a little shaping & cleanup on the grinding wheel the pieces are ready to tack into place.
                                A little heat & bend to get the shape right.
