38 Indian Chief
  • Bills37
    • Jan 2010
    • 247
    38 Indian Chief
    I've been hauling the frame, front end & wheels for a 38 Chief for the better part of 35 years. I guess it's time to fish or cut bait with it.
  • Bills37
    • Jan 2010
    • 247
    Remove the rubber bumper from the front fender and found some original paint.
    I also found that I had a pair of correct cylinders, they're in rough shape but they can be saved. More on that later.
      • 965
      I also have a 38 chief project,but I am no expert.
      I believe your cylinders are 35-37.I believe the lowest exhaust port fin is one fin with the cylinder on 38-39 chiefs.
      • gww
        • Dec 2011
        • 143
        fish on. that chum n worked.
        gww57.com
        • Bills37
          • Jan 2010
          • 247
          You sir are correct. The rest of the engine is a 37 too. It's what I got on the shelf. The purist can cannibalize it after I'm gone.
          • Bills37
            • Jan 2010
            • 247
            The bore for the kicker shaft was egged out so I cleaned it up and installed an oversize shaft in it.
            • Bills37
              • Jan 2010
              • 247
              Things are progress nicely, I've got a rolling chassis at this point. A big thanks to Greer Engineering for powder coating and lacing the wheels.
              • Bills37
                • Jan 2010
                • 247
                These showed up last week, I've been waiting for a year.
                Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
                • Shaky Jake
                  Ol' Poop
                  • Jan 2013
                  • 261
                  Looking good... keep going!
                  Kevin
                  Kevin
                  • Bills37
                    • Jan 2010
                    • 247
                    Rut Roh, I've got a little fitment issue.
                    The left tank is pinching the speedo cable against the frame.
                    The lower right mounting hole does not line up.
                    • Bills37
                      • Jan 2010
                      • 247
                      The speedo cable issue was easy enough to deal with. I just took a ballpean hammer and pounded a little more relief on the inside of the tank.
                      The mounting hole took a little more work. After talking it up with people who have been doing this a lot longer than I have. It was agreed that cutting the tab off and relocating it was the best solution.
                      • Bills37
                        • Jan 2010
                        • 247
                        • Bills37
                          • Jan 2010
                          • 247
                          Aaah, perfect fit.
                          Fill in a little of the welding undercut and I'm all set.
                          • Shaky Jake
                            Ol' Poop
                            • Jan 2013
                            • 261
                            Shazam!
                            Kevin
                            Kevin
                              • 6017
                              Fantastic pictures, Bill. I love seeing set-up, and machining pics. Obviously, you have everything you need to fix any problems that come up Thanks for posting the pictures.
