Good thing your wife was out.
27 JD Restoration
So, more progress......... !
1st is picture of the spanners i had made up for tightening the sprocket and brake drum ring nuts.
2nd is picture of 2 different types of cylinder primer cups. one is original, the other reproduction. which type is correct for 27 ? another question, is the reproduction an accurate copy ? looking at 22-27 and 27-31 parts books, looks like there is no distinction between the two, one pn = 49-14. somewhere, and i cannot find where, i thought i saw the flat face (repro) was correct through 29...... and the cupped primer 1930-onward.........?
20160420_163446.jpg20160420_190938.jpgSteve Swan
27JD 11090 Restored
27JD 13514 aka "Frank"
Steve,
The Replicant Metals website shows the cupped primer for 1930 -36. It has some good pictures of both types for comparison purposes.
Hope this helps.
Thanks, Peter! Thaaaats where i saw the 2 types... and, that's where my questions came from..... my original 27-31 parts book show only one pn for the primer cups, "49-14..................1915 to 1931" i am assuming the original 49-14 cups are flat.Steve Swan
27JD 11090 Restored
Steve Swan
27JD 11090 Restored
More pics. won't be able to continue for a few days, when i get back to my shop, will clean up tanks, install, then on to wiring and miscellaneous details.
20160427_224354.jpg20160427_224406.jpg20160427_224437.jpg20160428_013712.jpg20160427_224340.jpgSteve Swan
27JD 11090 Restored
started working around 2pm and went til midnight. got control cables cut to length, spark and throttle adjusted and cleaned tanks. (the spark control coil could be about 2.5 inches longer, the ordered length of 60 inches is just short.) I'd appreciate knowing who to contact to buy a length longer than 60 inches. Next, on to wiring and getting the clutch controls.
these little round connectors, how do they attach to the wire ? seems there is probably a tool necessary to do the crimping ? what does the tool look like ? or, where can i purchase one ?
20160512_214441.jpg20160512_214315.jpg20160512_214238.jpg20160512_214221.jpg20160512_214202.jpgSteve Swan
27JD 11090 Restored
here is a picture of the eyelet
20160512_215300.jpg20160512_215331.jpg20160513_025007.jpg20160513_104329.jpgSteve Swan
27JD 11090 Restored
Steve Swan
27JD 11090 Restored
You've really made some progress Steve, and your efforts really show. In regards to the wire grommet, I would suspect it would be very similar to a grommet tool used for canvas tents, tarps, etc. I'll bet you could find some good pictures of the tooling on the web, or ebay. It's possible there is a tool set just for your size, but I think you could easily make one on a lathe.Eric Smith
i now have the bike wired. i was able to find a 14 amp hour sealed lead acid battery that fits perfectly inside the plastic faux original battery case Replicant sells. i stuck high density foam on the battery it's self and the dimensions are now the exact dimensions of the inside of the case. once the clutch pedal and clutch pull rod are ready to use, the bike will be ready to start and test ride.
20160517_001124.jpg20160516_232012.jpg20160517_000841.jpg20160517_001004.jpg20160517_155811.jpgSteve Swan
27JD 11090 Restored
that will be a big day for sure ! i'm finding at age 64+ i'm no even close to the hurry i used to feel 20 or even 10 years ago ! i do have a bit of content anticipation, though ! 11090 will be ready when it is ready ! i'm still in a bit of disbelief i'm at the stage the bike could actually be started.Originally posted by TechNoir View PostIts looking good Steve. Not far to go, I bet you are itching to get it finished and ride it.
Looking forward to your next update.
JohnSteve Swan
27JD 11090 Restored
Steve
What's the make and part number of that sealed lead acid battery?
My friend Geoff Erdos makes that case that Replicant sells and I'm sure Geoff would like to know about a battery that fits. Especially a 14AH battery.
Mark MasaMark Masa
www.linkcycles.com
