Could someone tell me how to assemble the shift arm and gear in the top cover of my 47 knuckle tranny? I know how to do the rachet lid one,but find a clear explanation on the hand shift one.
Hand shift top assembly
hello george----look at the gear on the shifter drum----one of the teeth has a bevel on it. you have to time it with the other big gear on the end of the shaft. 47 and up the arm goes down 46 and earlier it goes up. the gears are timed the same though just the position of the lever is 180 out. once you find the beveled tooth, count the grooves in the other tooth. the beveled tooth goes in the 6th groove from the left in the picture
join up here george http://www.caimag.com/forum/ don't forget to introduce yourself as a new member---some are thin skinned----i never did that because i didn't know. sensitive bikers----who knew???
