Hand shift top assembly
  • gallen
    • Sep 2006
    • 60
    Could someone tell me how to assemble the shift arm and gear in the top cover of my 47 knuckle tranny? I know how to do the rachet lid one,but find a clear explanation on the hand shift one.
  • flat-happy
    • May 2009
    • 543
    hello george----look at the gear on the shifter drum----one of the teeth has a bevel on it. you have to time it with the other big gear on the end of the shaft. 47 and up the arm goes down 46 and earlier it goes up. the gears are timed the same though just the position of the lever is 180 out. once you find the beveled tooth, count the grooves in the other tooth. the beveled tooth goes in the 6th groove from the left in the picture
    • gallen
      • Sep 2006
      • 60
      Flat-Happy
      Thank you for your reply. I understand the timing of the shfter barrel to the gear,but how is the gear on the shaft positioned. Thank You
      • flat-happy
        • May 2009
        • 543
        join up here george http://www.caimag.com/forum/ don't forget to introduce yourself as a new member---some are thin skinned----i never did that because i didn't know. sensitive bikers----who knew???
          • 6041
          That kind of turned me off that forum. Stand up and introduce yourself. What's your favorite color? . . . Geeze, what is this; A.A.
