Late Model Servicar Intake Manifold Sought
  • Paps
    • Jun 2003
    • 1814
    My buddy needs a two bolt intake manifold for his servicar. Carb is an L&L 1966-72. HD #27020-66. Earlier two bolt won't work with the carb. Thanks, Paps
  • flat-happy
    • May 2009
    • 543
    is this what you are loking for paps?
    http://cgi.ebay.com/ebaymotors/Tilts...item4cecd89b82
    or maybe this?
    http://cgi.ebay.com/ebaymotors/tillo...item4cecef9076
    • flat-happy
      • May 2009
      • 543
      or maybe rhis one?
      http://cgi.ebay.com/ebaymotors/Harle...item25581585b7
        • 8231
        The first ebay link looks cobbled to a home-made flange.
        Is there really a difference between the DC and Tilly bolt spacings?
        Or any other modern carb?
        TIA again,
        • steve hartley
          • Nov 2009
          • 6
          I don't think so Tom. I believe that any carb of the 2 bolt variety with verticle orientation and made for HD's will bolt directly onto any servi 2 bolt intake.
          • Paps
            • Jun 2003
            • 1814
            Then why the 66 part number ? Paps
            • steve hartley
              • Nov 2009
              • 6
              Bendix and most likely keihen, although I don't have one in hand, are 2 3/4", DC's 6 & 7 are 2 11/16" and the tillotson MD119B is 2 1/4". Assuming the 119A is the same.
              Can you provide the measurement of your model DC's mounting? The manifold?
              Sorry for the misinformation.
              Looks like I'll need a late model manifold myself which is apparently what your buddy has.
              • Paps
                • Jun 2003
                • 1814
                Here is a pic of the carb. Paps
                  • 8231
                  Nobody's got a late Servi Parts Book?
                  I wonder if the MDs were golden like the DCs?
                  (Nevermind, I don't need to know.....!)
                  • steve hartley
                    • Nov 2009
                    • 6
                    The pictured carburetor is not an L&L and should have in very distinctive lettering the following:
                    TILLOTSON.
                    It also has a model # on it which will tell whether it is for a 1966 but I think it is not. Appears to be a B model.
                    • steve hartley
                      • Nov 2009
                      • 6
                      Originally posted by tst
                      The picture is of a tilitson carb with a bowl which is correct for a 66 to 73 servi, the part # for the intake manifold you need to fit that carb is 27020-66
                      Tim
                      It appears that the carb is a 119b and the 66's I've seen have 119a's.
