A few questions. Oil pressure is about 20-25 psi with 50w on start up. Is this good?
I was watching the return line in the oil tank to make sure I'm getting return, and it's not a steady stream. More like spurts every second or two. Is this expected?
I noticed that the primary chain is not getting oiled. I messed with the adjuster screw, and still couldn't get it to oil. I even pulled the screw completely, and noticed the screw was completely dry. Isn't the primary chain oiler on the same 'circuit' as the cam gear galley? How do I know if the cams are getting oil? I'm returning oil fine, and the gauge shows 20 pounds. The cams do sound noisy, but I guess I expected that. I just don't want to do any damage. Should I pull the oil pump and check the springs and balls?
Just concerned.........
Got a piece stuck on the coat hanger........PAPER TOWEL. Stupid me. That's what I get for taking years to rebuild this thing. Forget what you've done. Probably stuffed some in there to bead blast, the pressure forced it down the tube, couldn't see it, then forgot all about it.
