Early excelsior clutch 1917
  • danf19
    • Apr 2013
    • 246
    I am trying to reassemble my early 1917 Excelsior clutch. It’s been a while since I took apart, and of course I can’t find the pictures that I took when I did that.
    Would anyone be able to tell me the order of the steel and fiber disc and also do the springs get any sort of lube?
    Thank you I’ll post some pictures later
    Dan
    This gallery has 1 photos.
    • 6041
    Hello, Dan. These pictures are of my 1916 Excelsior clutch. I believe clutch disk picture is the correct sequence of steel, and fiber disks.
      • 6041
      I recall that the pressure plate springs are protected from the elements, but could use some light 'Never-Seize' lubricant but don't get any on the clutch plates. Beautifully made clutch, but needs as much attention as a new-born baby to keep it happy.
      • danf19
        • Apr 2013
        • 246
        Thank you . Did you reuse your fiber disc or purchase new ones ? If so from whom? Are the new ones Kevlar ?
        What other “attention “ do they need ?
        I notice that I have one more steel disc and one more fiber . Did they vary ?
        thanks
        Dan
          • 6041
          I would put it together and see if the stack-up works within the limits of the pressure plate. To (many)high, or (few)low plates will be determined when trying to thread (and adjust) the big threaded ring on the pressure plate to the clutch basket. I don't know the source of the fiber disks but I would assume Kevlar would be ideal if available. The high maintenance items are those thrust bearings, and the balls inside the clutch hub. The clutch on my '16 worked quite well but surprising how little pedal movement was needed. Definitely took some 'getting used too'.
            • 6041
            I don't know if any of this will help you, Dan; but pictures can give perspective and placement. Selling that '16 X was 1 of 3 incredibly stupid motorcycle deals I have done. I worked harder on that '16 than any motorcycle I've owned or will own and the end result was a good running, attractive bike that I will miss till the day I die. These are pics of the open transmission, and clutch hub, shell and bearings.
            • danf19
              • Apr 2013
              • 246
              Thank you . A few more questions ….…. Is there a bearing behind here ? If so, how to access it without damaging parts . I see no set screw etc .
              I believe I’m supposed to to have a fiber disc riveted in here. Anyone know anyone making the fiber disc or who can do the work ? Guessing it’s a pretty high strength situation or perhaps adhesive ?
              again thanks ,
              Dan
              This gallery has 2 photos.
              • danf19
                • Apr 2013
                • 246
                Answered my questions . Yes bearing but can’t get the outer ring cover off. Thought it was thin but looks pretty hefty . Any suggestions on how to replace the bearings ? Also, suggestions on bearing replacement in terms of a modern or who might sell the original ?
                  • 6041
                  Sorry for the delay, Dan. Those pictures go back 10 plus years ago so I'm a bit hazy on how I got the balls out. I seem to recall that I made 2 small picks out of welding rod and ground the ends to fit between the balls and probably put a hook on the ends to pry a ball out of the relief grooves in the inner and outer races. Once you get the first ball out, the rest get easier, and easier. Perhaps someone else has a better method, or better material for the picks. Also, patience, and a good vocabulary of really dirty words helps.
                  The following pictures show an on-size 5/16" ball, and a 1 mill under ball. I don't know why I may have used an under-size ball but I would bet Excelsior specified a standard 5/16 ball. You can get balls from McMaster Carr or Jack Daniels but I prefer McMaster Carr for this application.
                  • danf19
                    • Apr 2013
                    • 246
                    Thank you so much ….. did you add the grease fitting ?
                    having a heck of the time getting out the initial bearing . Thank you
                      • 6041
                      I did add the zerk grease fitting but I don't recall if I had to drill and tap a new hole, or if there was an existing hole. Here are a few heart breaking pictures of my '16.
                      • danf19
                        • Apr 2013
                        • 246
                        Thanks and it’s beautiful ! Do you recall where you got the paint mix ? I’m still trying to sort that out . All the formulas keep changing as supplies change or go out of business. Thoughts ?
                        thanks
                        Dan
                          • 6041
                          I do have that paint code but couldn't find it on my first search, so I'll keep looking. I know it was single stage Dupont acrylic enamel. Unfortunately, Dupont sold that business off to Axala and the color codes changed. Also, there are fewer automotive paint suppliers these days and it is difficult to find anyone that will sell paint to armatures. I painted a lot of parts for my 1919 Henderson early this year and had a hard time finding a supplier to match and mix the paint. . . I could go on and on about the current state of automotive paint but that would prove I am a crybaby. . . Enough of that; it's basically a cool light gray, not warm. Don't be alarmed but I used Krylon bright red foo-foo can paint for the red panels and after fully curing it worked great and a lot less expensive that buying a can of automotive paint. The red panel is bordered by a maroon 7/16" stripe and that stripe is edged with gold inside, and orange outside. A medium blue pin-stripe is used on everything else, and the frame. Finally, a double red stripe on the wheel rims on a 1916, based on Jerry Ottaway's gorgeous original paint 1916 Excelsior. That color scheme may have been on earlier X's and the early 1917 Excelsiors.
                          • danf19
                            • Apr 2013
                            • 246
                            Thank you so much…. Back to the bearings …. Are you using grease or heaving oi thru the fitting ?
                            thanks
                              • 6041
                              I've been using Timken bearing grease on rollers, and ball bearings in my older, early bikes. I have to believe there is some modern super lubrication that I'm clueless about and hope someone can enlighten us with a recommendation. I have to think that routine cleaning, and maintenance is probably better than any super grease, but I am a fan of being lazy and letting super stuff do the hard work I am too lazy to do.
                              So, no one got my lame joke about getting Jack Daniels balls? Am I that crass, and infantile that only I think that's funny. If that's true, I need some serious self-introspection.
