Harley shifter drum # 34016-52
  • 1970 XLCH
    • Nov 2010
    • 177
    Can anyone tell me what shifter drum part number 34016-52 is ? I see them on eBay but cannot find it in the parts catalogs , or Palmers book . Everything I see , has part number 34008-52 as the early foot shift drum .
    • 4785
    The number stamped into the drum is a casting or production number, not a part number. The number in the book is the part number and they do not match.
    • 1970 XLCH
      • Nov 2010
      • 177
      Thank you Rubone . Their are three 34016-52 drums right now on eBay , one is not for a foot shift , but one of the other ones has written on it " NOT 4 SPEED " The reason I am posting this is that I have one in my ratchet lid & have set it with the shifter forks with the proper Harley tool & am having problems shifting it .So I took the lid off & went through the gears ( 1st , neutral , 2nd , 3rd & 4th ) I placed the lid on for each shifter fork setting & it goes on easily for all EXCEPT for 1st . The lid didn't come with the tranny . It looks like the grove in the drum for 1st is a little short of where it should be . Anybody had this problem ?
        • 4785
        Never heard of any odd drums. There are 4 speed hand shift, 3&R handshift (also '39 only 4 speed) and footshift 4 speed. Until you get into the cast drums in the late '70s that is all there is. I have several here. Ive never had an issue putting any year pre-rotary top on any other 4 speed box.
        • 1970 XLCH
          • Nov 2010
          • 177
          Thanks Rubone ! I'm always a " Special Case " . I'll get farther into it . Will let you know what happens .
