shift fork p/n 24160-36
  • coleleman
    • Mar 2022
    • 2
    looking for a shift fork for my 1939 El on the counter shaft side any body out there have any sources
    • 2032
    I have some
    • coleleman
      • Mar 2022
      • 2
      Great. Need 1 for my 39 el
      How do i , buy one
      john
        • 2032
        Sent Message....Correct part, tags have wrong number
        • dukekleman
          • Jul 2022
          • 595
          Those are Fun!
          I just rebuilt a 39' EL 4 speed transmission this winter.
          IMG_20241214_095938383.jpg IMG_20241214_110531848.jpg IMG_20241214_103042931.jpg
          Be sure to get the fork alignment set,
          Duke Kleman
            • 2023
            Originally posted by dukekleman View Post
            Those are Fun!
            Duke Kleman
            Has anybody ever figured out why HD built that miserable 1939 4 speed?
            Jerry
            • dukekleman
              • Jul 2022
              • 595
              Jerry,
              That is a good question.
              It was short lived...
              Duke Kleman
                • 4785
                I believe it was some bean counters attempt to convince the MoCo to save money with parts commonality with the 3 speed, 3&R, and 4 speed sharing some parts. Customer and dealer feedback (most likely Police like the CHP and LAPD that bought lots of bikes ) put a quick end to the crashbox style. It was a grim time financially then.
                  • 2023
                  Robbie
                  Yes but the early 3R shared as many parts with the early 4 speed as did the later 3R and the 39 4 speed. It doesn't make sense.
                  Jerry
                    • 4785
                    Originally posted by Jerry Wieland View Post
                    Robbie
                    Jerry
                    True Jerry, it does not. But if stuff always made sense life would be a bit boring...
                    • JOHNNYJET
                      • Jul 2025
                      • 4
                      Hey Jerry, how did you get your fork alignment tool to work on both forks,
                      I finally just use the lid om my 39 EL
                        • 4785
                        The alignment tool works just fine on any gearbox from '36-'79. The neutral position is the same for all gearboxes despite internal configuration.
                          • 2023
                          Johnny It should have worked just like with other 4 speeds.
                          Jerry
