Cam Chest Spacers
  • dukekleman
    • Jul 2022
    • 598
    Cam Chest Spacers
    I'm looking for information regarding the cam chest spacers used from 1936-1969 under the gear cover on the timer gear shaft and idler gear shaft.
    The part numbers are 25800-36 and 25800-36B
    Does anyone have a shop dope/service bulletin they can share regarding this change over?
    Photos of each shown below
    Thank you in advance,
    ​​​​​​ Duke Kleman
    • 2025
    ​​​​​​ Duke Kleman
    The top one is early. 1936 to sometime in the panhead era and is held in place with a snap ring.
    The bottom one is later pan through 1969 and eliminates the snap ring.
    • dukekleman
      • Jul 2022
      • 598
      Jerry,
      Thank you for the reply. I was aware of that information, I guess more curious if anyone has the shop dope/service bulletin information regarding the update change
