Transmission identy
    • 4791
    #31
    If you have a 54-64 Panhead you can install the longer 65 sprocket shaft to line up to a 65-69 transmission.
    Almost,...'56 up is a bolt in, '55 is changing at least the left flywheel, '54 is a no go, it is a tapered shaft.
      #32
      As usual Robbie is correct.
